Help/lowered to stock maybe lift
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no prob id check it before if its the new version will work.
Rear kit rides bad i havent used the rear springs in years the tb new version spring i sell sits lower and rides better. You will see the rear will ride bad especially with the djm shocks/djm 5 inch springs
magicbus
Wichita Falls, TX
Right on, I'm already planning on the rear being temporary. I like cali lean so they will more than likely not be low enough for me anyway. I am contemplating running air in the back either with a standard bag or the trailblazer bags. I'm torn between air and the 6" springs you have advertised.
godoy
godoy
utah
So anybody want to help
I think I know how to change rear
Unbolt bottom if shock unbolt swaybar. Bolts and raise truck up and change springs right ? Oh and the trailing arm bracket right
And front I have no idea
Alex33
If you can do brakes, it's pretty straightforward. PM me and i'll give you a rundown.
godoy
godoy
utah
Ya I can
Thanks and ill pm you once I get some days off work
Do I really need stock trailing arm brackets ??
Alex33
Ya I can
You should have OE RTA brackets. You just got the 3/5.5 kit, right?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes in rear you will need to ditch the trailing arm relocators
in rear you will need to put the stock endlinks backon
godoy
godoy
utah
And put back stock trailing arms??or just bolts right up
And Stock endlinks are necessary?
---------- Post added at 09:50 PM ---------- Previous post was at 09:48 PM ----------
Only reason I'm bringing it back to stock is because I might sell the truck (might)
But the lowering kit is nice and have no problems with it!!
Alex33
Just bolts right up. Stock endlinks will def help but you could get by without them.
Shadfrmdabull
