Help me build my suspension..
Tahoewhat
Ballin' on a Budget
TX
If you want to slam the front, couldnt you get the 2" drop spindles and the 3" Lower A-arms? and be 5" w/ that? and then you would still be able to crank the keys. I have the McG. drop spindles and keys up front. Right now, my keys are cranked up all the way. And its still low. THink if i de cranked the keys, which i dont like the ride doing that, but i could probly tuck a little of my tire.
they make a 16" drop spindle, that way you dont have to buy new rims/tires right now.
BlizzardX23
Sacramento, California
16 inch wheels spindles wont work.
Yes they do...I have 16s and spindles....the same drop spindles I was using when I had my 22s
Take a grinder and grind off the excess bolt and file the nut to take off the edge...its easy, dont let people tell you its hard, or will be unsafe..they dont know what they are talking about...you can use a hand file, thats how minor it is
Leaves you with a truck on 16s, spindles, and no harm or damage to truck
This is my truck with drop spindles, lowering keys (maxed out as HIGH as they will go, not as LOW...I could lower the front A LOT if I wanted)...and this is my 5 inch drop in the rear
This was on 22s...before I did my body drop I believe
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
do the 3/5.5 and call it good.
Smityinms
