Ben Hinz
You planning to run x12's and 33's on a 2" level? I had that on a 3.5" RCX and had to cut like hell to get full crank, norcal and everything. Looks good but just beware that's an insane amount of cutting you'll be getting into.
Wasn’t that bad in the cutting. Took like 2 hours to get done. I’m thinking of running a 0”-3” lift Coil over from Fox Shocks and getting new UCA. I want it just a bit higher. Prob end up with a 2” space in the back so it’s a 2/3 lift. Should look good!
