Help me decifer this new to me Denali's autoride
In response to Christoph559's post and the fact that mine is not holding air I looked for a description of the system and found this
http://www.underhoodservice.com/servicing-gm-autoride-rear-air-suspension/
With this in mind I'm going to see what I have now.
Are you sure yours isn't holding air or maybe your compressor isn't turning on at all? It's easy to check for air pressure- first, start the engine and go listen back by the rear for the sound of the compressor turning on and running for a minute or so. (This will only happen if it's been sitting for overnight or similar amount of time)You should notice the rear lift up a bit. Then shut off the engine and pull the metal clip on an air line at one of the shocks and air should release and the suspension should settle a bit. How are you determining that you have no air in your system ? It's hard to tell by looking at your shocks.
PatDTN
My air shocks look like a dude who's been in cold water too long. Plus the bags are crunchy they're so dried out.
I started in to work on this today but got sidetracked moving stuff around in my garage. So far I've put the rear up on jackstands and crawled around a little under it. I laid eyes on the linkage onto the rear suspension to detect ride height and the compressor behind the left rear wheel.
I need to get the front up now so there's room; I want to rotate the crap Wranglers off the front and go with whatever is on the back to see if I can reduce the tramlining a bit.
N
NateDiggity
So I got mine pumping up, and that is working, but now I seem to have a leak, the compressor will go out if I keep driving it like this, it seems to kick on every few minutes. Odd thing is after I drive it for awhile it doesnt anymore, but its in a protection mode...
I climbed under there with a spray bottle of soapy water and soaked my lines at the comp, the tee and at both shocks, as well as the shocks and didnt find anything. After doing some searching and finding another thread I was told to paint on the soapy water with a paint brush and then fire the truck up to check for leaks... not sure how this differs greatly from my plan but its worth a shot. I was also told to soak the compressor itself as it will sometimes have a leak between the compressor and dryer, I did not do this and I will check that over closely... I would have thought with the compressor kicking on that much that I would have heard a leak but never could.
Also how loud is your compressor? Mine can be heard from 30' away with the motor running, is this substantially louder than normal?
I need to stand close to my truck to hear mine but it's a new Arnott replacement; unsure how loud an OEM one is. As far as checking for leaks- if a bladder on your shock is blown out you won't hear a leak I doubt since there won't be any pressure built up due to a large hole. These systems deal with a minimum amount of air- the air lines are tiny on the inside. They do have a significant amount of pressure I believe. It could also be that your compressor isn't actually pumping any air. Take a line off at the tee or a shock and get the compressor to turn on (if it doesn't automatically) by disconnecting a ride height sensor and simulating a heavy load by moving the rod up (like the suspension is moving up). Then see if any air is coming out of the line. You need to see if there's air actually being pumped into the system before assuming it's leaking out.
PatDTN
I'm trying to sort out the ALC on my 09 LTZ. Today I popped off one of the wheel height sensors and shoved it up high enough to think the tire was going to come through the roof soon. Nothing happened.
I decided to skip ahead to the compressor. I unbolted the entire compressor setup with the 3 13mm nuts. Too bad I didn't realize those don't have to come all the way off because the frame is keyhole notched for them. It was looking pretty cruddy in there.
Reading around on line I saw where someone just applied 12 volts across the red and black terminals in the connector and their pump spun. I tried that and got arcing and sparking like a dead short so I quit that. My best guess is the compressor is burned up. Oddly the 40 amp fuse and the little 30 amp near it under the hood are both good.
Before I spring for the complete Arnott compressor setup - mine was so rusted I couldn't disassemble the box - what should I test.
I did use my garage air compressor and blow up the rear shocks through the line from the compressor. I could just get my pinkie in there to block the line and it seemed to hold air. It raised the vehicle a couple of inches. Obviously holding my pinkie in there I couldn't run around and spray or brush soapy water on things but it seemed stable and I didn't hear air leaking.
I'm aware of the control box under the dash and the sensors on all 4 wheels. What else can go wrong? How can I test for that?
Thanks!
One other common problem, and it happened to mine, is the compressor ground. The lug where it attached to the frame was rusted and it wasn't making contact so my new compressor wouldn't turn on. Mine is a different body style (2002), but I have a fuse labeled RTD (real time damping) in the underhood fuse block that operates the compressor. You may not have that but if you do, check it. Since you checked your compressor by applying 12v and ground, it must be bad so I don't see any issue with buying a new one.
02Lightning
I would get the Dorman compressor, comes with new bracket and you don't have to splice wire.
PatDTN
I ordered the Arnott complete compressor with bracket from Shockwarehouse for $209.00 with free shipping. With luck I'll have it by Friday. It's a direct drop in and comes with two wiring harnesses for some difference.
PatDTN
Sorry for hogging this thred. Got my complete Arnott compressor assembly today. I took the old one out when I realized it was shot. Remembering how accessible that is I grabbed a 13mm deepwell socket and slid under on a mat with the new compressor. It was completely installed in 15 minutes and pumped up and stopped when I started the Tahoe. I'll see if my system holds air after having been run for doG knows how long with no air in the shocks.
Looking like $209.00 well spent.
Awesome to hear. Hoping you're all set. And no need to apologize.
SLOGoing
