After spending about $4500 on my 2007 Tahoe to replace my transmission that finally turned, and new wheels i tapped out when i got the quote for bad upper control arms & ball joints...
Ive just completed my site wide and forum specific searches, as well as youtube and google - but damn - i still feel like I wanted to be certain ill be on the right track and pick up as many nuggets from anyone willing to offer up their .02.
A bit of a history first - since I was taking the tahoe into the dealership for a considerable amount of work / maintenance that needed to be done back in May 2017, I thought who better to install the Belltech lowering kit, alignment kit and sway bars than the dealership.
After the install the front wheels had a notieable cant while looking at the alignment from in front, sometime after the work was done - it was easy to tell the alignment was off...being busy and procrastinaing i let my front tires wear down to the threads nearly on the inside of each of the front wheels...
I thought I would take it back in after only 8k miles and only a few months had passed to see how the customer service would save the day - yea not so much... so just ~4 weeks ago basically all i got out of it was another alignment... I didnt do the research to investigate things until today when i was told about the UCA & ball joint issue then consulted a friend, then spent hours searching online...
My main question and concerns are regarding what/if anything outside the norm might be needed or recommended for a lowered tahoe - when undertaking this myself?
The dealership installed the following in May:
Belltech Lowering Kits with Street Performance Shock Absorbers 737SP https://www.summitracing.com/parts/BEL-737SP
Belltech Wheel Alignment Kits 4957
https://www.summitracing.com/parts/BEL-4957
Belltech Anti-Sway Bars 9909
https://www.summitracing.com/parts/BEL-9909
I still have the factory 17" allow wheels, I did have IronMan All Country 265/70's put on today as well.
Ive seen where Ill likely have to rent a ball joint press, if i go the route of not replacing the upper control arms... Ive also spent some time looking for some good schematics (which ive just referred to from gmpartsonline.net) to reference possible bolts/nuts etc I may get prior to just to put new parts in along with the other parts...
Should I stick with factory replacement parts or look at another manufacturer for some or all of the parts?
Stock Parts-
Both Left & Right Upper Control Arms (comes with upper ball joint and bushings):
https://www.gmpartsonline.net/oem-p...vPXRhaG9lJnk9MjAwNyZ0PWx0JmU9NS0zbC12OC1nYXM=
Or something from MOOG:
http://www.moog-suspension-parts.com/products/chevrolet_tahoe_2wd_2007
Any help appreciated!
Stock Parts-
