mikeheff
Thanks in advance to any suggestions/help anyone can give me. I have a 1996 Tahoe that keeps getting code p0121 (throttle position sensor circuit A low output) I have replaced the tps with genuine ac delco part, checked voltage , grounds. I installed a new connector on tps, rewired it straight to pcm in correct terminals, soldered wires. I did this in case there were a wire rubbing in harness that I couldn't find. Still get code ! I got a used pcm with same serial number as original. I plugged it in and runs rough, I assume it will need reprogramming. Does anyone agree replacing pcm is the only thing left? nothing else left in that circuit that I know of. This is getting frustrating to say the least, so if anyone has experienced this please give me some good advise.
