Help on lowering '97 2dr 2wd Tahoe on 24's
Priv41510
Bay Area, CA
I have 24x10 Lexani Firestar's 5lug 20mm offset on 255/30/24. The tires are way to small for my taste I plan on getting a bigger tire like 295/35/24 or whatever size I can fit in the fenders thats bigger than the 255's after the drop.
I wanted a 4/6 drop or even 3/5 but some advice would be great with some experienced members...
I heard DJM lower A-Arms with stock sping/shock set up, OR spindle and coil combo. I was also told by a few shops that 4/6 and even 3/5 will rub with 24's and that 20mm offset will cause problems so go with a 2" drop.
Basically I want to go as low as I can with those rims and still maintain alignment, ride quality, and I'm cool with rolling the fenders too.
ok so any help would be appreciated and thanks in advance!
peace
David
chevyguy0211
Is this guy still around?
Your 24x10's wont work without narrowing your arms, and pushing your balljoints forward. Especially with that drop, I'll be working on modifying arms so they do work. But you'd still have to tub your fenderwells.
Sent from my DROID RAZR using Tapatalk 2
the burbalac
