HELP - Only Starts with Camshaft Sensor Disconnected
Geotrash
Dave
Richmond, VA
See the link below and scroll down to the second diagram (Engine Data Sensors - 5-volt and Low Reference). Dead center is the Camshaft Position sensor and it shows the wire colors for the 5v Ref #1 (D-BU) and the ground (BN). That 5V Ref is shared by a few sensors on the left side of the diagram, but from different ECM pins.
Thank you, Steve. You saved me from digging.
E
evanw0920
Thanks, will try this out and get back to y'all.
E
evanw0920
I hope it helps. Seems like a short or lost ground on a circuit like that would set some kind of code.
Hey guys, finally got the new sensors in to no avail. I did test the wires and there was 5v. Still just cranks but doesn't start unless I unplug the sensor. Still no codes either.
Is the only other possibility an issue with the ECU?
I did check the timing chain and it hasn't jumped timing.
Thatmario956
