Help reading freeze frame
laprodigy001
I have codes p0141,p0171, and p0174. I here is a freeze frame .
Does anyone know how to read these freeze frames? I want to get some more of an understanding on what went wrong if possible.
Thank you99ec5b347098cbb5c9abafae3e7e7a4a.jpgccb669bf53d5e1d3fb4eeab94e70f342.jpg586e568dd14220c585e51fcafca1a1c1.jpg5255cd8c0f3424b25b3c765e95f4dd02.jpg0a532a96248ae847f4667a14135a2e3c.jpg
Sent from my LG-H830 using Tapatalk
Scottydoggs
NJ
laprodigy001
laprodigy001
could that be because I have a 4x4 and I don't have my front driveshaft on.
Scottydoggs
NJ
Symptoms of a P0719 code may include: Engine stalling when the vehicle rolls to a stop TCC lockup may be disabled Diminished fuel efficiency Decreased engine performance (especially at highway speeds) Erratic transmission shift patterns No stop lamp illumination
Read more at: https://www.obd-codes.com/p0719
Copyright OBD-Codes.com
hit that link theres a long list of test to do, its tranny related, tc lock up, so id be guessing it screams high rpm's in every gear.
laprodigy001
laprodigy001
Not at all. No screaming or noise at all.that only apears when I do a full gmc scan on my odb2 Bluetooth thing. That started apearing after my truck was stuck in 4 feet of mud and water a few years ago. I'm more interested in the p0141,p0171 and p0174.
Scottydoggs
NJ
being it sunk good im willing to bet you tore wire apart or or popped a plug or two off when dragging it out. time to check the front hubs, the wire from it are for the abs. under it on the tranny a plug might be off or broken.
laprodigy001
laprodigy001
So that p0719 could be the front hubs? Would replacing them take care of the code?
Scottydoggs
NJ
the hubs are the C codes the rest are trans related.
like i said, you sunk it and dragged it out the mud, id be looking for damaged wires or plugs pulled off before buying a thing.
and a o2 code. could also be a ripped off plug or wires to it.
Jscan
