SunlitComet
OBS Jedi-Do Good
1. In that post I also said to much is never enough for me so the best solution for me with some older equipment was no solution. 18 remotes and counting with full control over every fuction on them. I do have a hp media center pc tied in not pictured with its own minidisc recorder with remotes for both. There is another older computer dedicated for storage and constant weather station data on display. Total storage =2.2 terabytes. Also 2 laptops(one old with serial and printer ports but no usb or network plug(pcmcia card for that) used mainly for rs-232 linking). Loaded business fay with neworking, storage and multiple trays. And to top it off networked HP inkjet and HP8100dnt w/2-500 sheet trays,2000-sheet feeder, envelope feeder with all trays capable of 11x17" tabloid paper, 8-bin output bin sorter and network with dedicated hard drive. Cost per page $.03 up to 150,000 pages a month.
2. 16-port switch, wi-fi router with phone ports for voip voice and fax use, 2 other wifi routers with access control options for others to go thru, 2 wi-fi access points for home theater use a few more switches and access points not pictured. Cable modem also has voip ports in use.
3. KDL46XBR9 was in production around in 08/09 but there are still new and used still around with 52 and 40 inches too.
CCFL 10-bit panel capable of full 1920*1080p/24. bravia 3 engine 240 hertzs motionflow. Four hdmis, two components(one switchable to composite), Two composite (one with s-vhs), ANalog audio in/out, Optical out for extraction from hdmis or tv digital/analog tuners, Pc input, usb connectivity, Lan port, streaming video and widgets and then some.
Dilibertly choosen over xbr10's and new 3d models. that lack video proccessing quality even while offering led light becuase they went with slower processors lower refresh rates etc. Older xbr8 had tri led but used older proccessors. New Sony XBR-60LX900 out now go back to high refresh rates better proccesors again and edge-led with 3D, wi-fi, no more s-vhs but go 60" inch big($4500). I will be getting one probably q4 2011or next q. Xbr is Sony cherry. For bedroom cant go wrong with and older xbr9 even used. Amazon dumped 30 scratch/denter for $980 in sep. where I snatched one. Save about $1200 over new.
BTW service manuals on everything.
Maybe on tha tablet but no money to even fix the truck right now.
Planned though so far is car audio with nav sytem will be kenwood excelon with rear view camera, hd and sat radio, dvd, Polk speakers Kenwood amps and enlosers for barn door subs($3600 retail). Alarm will be Clifford avantguard 5 with starter, window control, tilt, perimeter and sound sensors($700 stealth wired self install).
To much?
Need more info?
Need more info?
