Help Truck wont start Viper Done
BLKTah02
My keypad on my viper alarm was broke and i tried getting into my truck with the regular key and tried starting it and it wouldnt start, got aggravated and cut the speaker for the alarm off, what should i do now?? is there anyway to bypass this thing???
magicbus
Wichita Falls, TX
There are a few options, find main power for the alarm and pull the fuse. You should also be able to press and hold the valet switch while you start the truck to bypass the starter kill. You can also find the starter wire and re-connect it together since it is cut in two for starter kill on the alarm.
BLKTah02
BLKTah02
i cant use the remote cause its broke, but i can try to find the power and fuse, just dont know where to look??
GeneralNoobzor
Phoenix, AZ
This happened to me the other night. Lol, You have to disconnect the main power for the viper (Fuse or Plug) and the beast will start right up with your key in it.
(Valet Switch is the button on your antenna that is most likely on your windshield)
magicbus
Wichita Falls, TX
I have seen installers put alarms between the left driver air vent and guages, above and behind guages, directly behind knee panel (hack-jobs). I usually mounted them high underneath the dash (above parking brake pedal). So there are a few options. It will be a black box (more than likely zip tied in place) with a bunch of wires coming from it. The main power fuse should be somewhere on one of those wires. It is really difficult to tell you exactly where to look and what to look for since different installers all have different ways of installing.
Tahoe Fan D77
