Help with stock replacement sub using factory box/wiring/head unit
Ledesordre
May need an electrical/stereo guru to chime in.
2001 Tahoe LT with NON-Bose OEM stereo with factory subwoofer.
Factory sub was blown so I put this one in the stock box:
Polk Audio db840DVC 8-Inch Dual Voice Coil Subwoofer (https://www.amazon.com/gp/product/B0016GV1UU)
Upon getting it installed it sounds bad, the speaker is creating a lot of buzzing/rattling noise.
My question is whether the Polk sub that I put in brand new was bad, whether I have it wired wrong (ie should it be set up for 2 ohm or 4 ohm?) Is the Non-Bose factory deck/amp capable of running that?
Anyway to test the sub to see if it is still good?
Thanks everyone, can upload a youtube video of what it sounds like if that helps.
Ledesordre
Ledesordre
All right so i pulled the Polk subwoofer back out the factory box and took a look at it. I thought i'd update since I resolved the issue and I hate when I look at a forum post and someone has a problem and doesn't come back when the resolve it. Anyway--
It was the fact that my crossover wiring to wire it for 2 ohm instead of 4 ohm was pretty poor so it was causing noise. I re-did the connections and all is groovy now.
willinnashville
Nashville
Saw another thread where it did the same thing. I thought my computer was infected with some kind of malware, but I had a buddy do the same thing and he had the same result.
tdmcpa
