TxDrewski
A few months ago while daily driving, I noticed my temp was highe than the norm, which is a little below the halfway mark. Turned out I was low on water. Filled her up and the next few days, water was low again. Ive had this issue a few months now.... You can leave the truck running for an hour and stare at everything underneath it/around the engine....NO VISIBLE SIGNS OF LEAKING. Myself and 2 local mechanics attempted this. So it seems its only leaking while driving. No smoke, no water in the oil, no visible leaks. I lose 1.5 gallons of water every 100 miles give or take. I have replaced the following to no avail.
Radiator
Upper/Lower Hoses
Thermostat
Fan Clutch
Water Pump
Truck Only has 130k on it. Runs like a champ, no lag or missing power... Im all out of effing ideas....
Radiator
Upper/Lower Hoses
Thermostat
Fan Clutch
Water Pump
