Help
david98
York, NE
I did a intake manifold job on my 98 yukon. Got it all back together and now it won't start. What am I missing or mess up?
---------- Post added at 07:18 PM ---------- Previous post was at 06:42 PM ----------
Anyone have any input
david98
david98
York, NE
Yea I pulled. Got to start. Didn't have it lined up with everything right.
99Vortec
I haven't had to use this guide here yet....http://tinyurl.com/lob86tn
Looks like it assumes new install. Which you will need if you did not reference the dizzy and the engine has been rotated.
good luck!
Also keep in mind, I don't think that the author of the article discusses the oil pump drive shaft to bottom of distributor alignment. You are going to have to hold up the distributor and view it from the bottom, then make sure the oil pump drive is properly aligned before attempting the drop in.
*Edit* When you did the Manifold job, did you mess around with the injectors? Or just gasket replacement?
dwebster
