Hey Guys, I need some help with my K&N
Cobra
Austin, Tx. area
Dang I need to find it because I have never replaced mine. Guy at Autozone told me I didn't have one. Said it was built in to the fuel sending unit.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
I doubt yours would be different since mine is a Z71, but it is possible.
Wahpeton, North Dakota
Could one of you explain exactly where to look because I have been looking everywhere underneath that *****. Is it tucked up inside the frame because I followed the fuel lines and they run right next to and above the fuel tank then branched off into a unit with like four or five outlet stainless steel tubing. I would appriciate any guidance becase mine has never been changed either? Please help. Do I need to take anything off from the Yukon to get to it?
OmarR
Indianapolis, IN
04+ flex fuel - it's in the tank and you don't service it.
05+ - in the tank, flex and non flex
If your 04 is non-flex, it will be at the fuel line underneath the driver's door.
Cobra
Austin, Tx. area
Omar I don't know if my Tahoe is Flex fuel. But like the other guy said I followed the lines to a box, which I assumed was the fuel sending unit.. One guy at autozone said I didn't have another said I did. :emotions122: I guess I need to find out if I'm Flex.
Sorry Jonathan not intending to jack your thread.
Bo Prob man, mines not flex fuel either and I cant find that damn fuel filter. Spend 15 bones on the ***** and I only have one place to stick and I am not looking forward to doing that.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
My 04 is a Flex Fuel and it is right around the transmission crossmember.
---------- Post added at 08:13 PM ---------- Previous post was at 07:58 PM ----------
Just checked some tuning files:
04+ non flex is in the tank
05+ flex is in the tank
OmarR
Indianapolis, IN
Good update.
With 2004 being the changing year, I wouldn't be surpised if you found a little of both flex/non-flex with either in-tank or serviceable in the early builds.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Good update.
All 04 flex fuels have a return fuel system, with the fuel filter inline before the regulator. The intank systems have the regulator in the tank after the fuel filter.
Since the programming is different, there won't be any trucks with mismatched leftover parts.
BMPGBH
