Hi New guy here gonna need some help......
ckeister
HI. Old school gearhead here that was in the auto industry for about 10 years in my teens and twenties. Used to drag race, little circle track and demolition back in the day. I still have my 69 Camaro that I have owned since 1991, albiet sitting at the moment in primer. I have built several old school small blocks. New to and learning about the LS platform.
Upon retirement, I wanted very badly to leave the great state of California, but the wife would not go. So the compromise was to move up to the Sierra Nevada Mountains. Now she agrees I was right....
I bought her a 2007 Yukon Denali because she still works, has about a 25 minute drive and we do get a fair amount of snow. I thought I did my due diligence regarding the dreaded AFM and found that the 07 6.2 had the AFM components but not the tune in the ECM. All good so I thought....wrong.
I got burned, literally for the first time ever buying a vehicle. I'm pissed at myself for missing it. But the low oil pressure only showed itself at hot idle. I drove it, ran fine good oil pressure, extremely good condition and only 127K. Guy said he really only used it to tow his boat to the lake and back which was like 10 miles from his home. I noticed it was leaking from damn near every orrifice but after my test drive, I crawled all over that thing as it idled in the driveway and didn't recheck the oil pressure while idling. My bad. So 10K miles, 2 oil changes, and a bunch of work later, its just been a continual downhill slide to the point I can't drive this thing over 50 miles without the oil pressure getting to where my engine building brain just not drive it even though we have never had the low oil signal go off. Looks like at this point the cam bearings are toast.
I will be posting my troubles in the 07-14 engine drivetrain section and could use some experienced opinions as I decide how to move forward.
Thanks in advance
Welcome to the Forum from NH.
Pics of the truck, please.
You are already receiving clarifying questions from the knowledgeable folks on this Forum.
Only a relatively few early 2007 L92 motors actually had the AFM hardware installed, so if your motor has these AFM components, it must have been an early motor manufacture date.
What are your oil pressures? Normal oil pressure for these motors is 45+ psi at full operational temperature and 2000 rpms. Normal oil pressure for these motors is 20+ psi at full operational temperature and at idle.
As mentioned above there is an O-ring on the oil pickup tube connection, which will fail over time, and will result in very low oil pressure and idle at operating temperature.
Also try adding 2-3qts of extra oil, where it's overfilled. Try pointing the nose down hill on an incline. Start it and let it idle. If the oil pressure is now good you have a bad O ring on your pick up tube. These motors have a known problem with O rings getting brittle and hard, where it's sucking air--causing low oil pressure. When done, make sure you drain the extra oil. Good luck.
Bblack82
