hid off road light problems
chauncey0337
MLT, WA
Do you have a relay harness. I think it's flickering and not firing both bulbs because both ballasts are not getting the required voltage.
the big blue bus
the big blue bus
richmond, va
ive got them wired with a relay, 30amp i think from a ford. the power wire to and from relay is 14awg and the lights are grounded where the wire comes off battery to the fender. the passenger one always ignites always drivers when i flip switch.
ch4d
A Podunk town in Oregon
Found your problem your using a ford product lol but change the ground around a bit see if you find anywhere else that would work.
the big blue bus
the big blue bus
richmond, va
they are at the same ground and the passenger one always comes on drivers needs switch flipped. may try a nother ground for the drivers but atleast they both work now
bobby88
