Hid
blueflamed03
Oklahoma
if your headlights come on automatcially during start up, get the harness...if you have to turn them on manually, you dont need it. But cheap insurance they work more often, IMHO.
not sure what they mean dual in/dual out
gulleyman
TX.
Me three! I gotta order some for my '97 Yukon, the lights turn on when the truck starts. What do I need to get HID hi's and lows?
Diller
Cedarburg, WI
You can get hight, lows or both. You just need to disable your DRLs. Many here have had success with removing the DRL fuse. In my case on my '99 Yukon, my DRL module is burned out, so the DRLs don't work anyway.
Diller
'99 Yukon
'08 Hummer H3
99Yuk
Northern Ontario, Canada
I'm wondering why the fuss over DRL? I have HIDs on my lows, and I run DRL. It's no biggy. A year later everything still works. However I did run the 4-hi mod to keep the HID lows on when using the high's. Then I turned it into a 6-hi mod when I added my airplane landing spot lights.
BTW, I bought the harness, and it plugs in backwards on these trucks. I also used the relay too.
gulleyman
TX.
X's 2, what's up with disabling the DRL's?
I'm thinking I want to go with HID for both hi and lo, and even my spotlights :hmm:
sparg93
Expedition Tahoe
NJ
with stock lenses, won't you have a nasty scatter using HID's? (blinding other drivers)
Diller
Cedarburg, WI
No nasty scatter here on my '99. I did aim them a bit lower, since I went with the 55w kit. I hate being blinded by HIDS......and I don't want to be the guy doing the blinding :mad3:
I don't thik there is a big fuss over diabling the DRLs. I personally don't like them. Every car I have had, I disabled the DRLs. Just my preference.
On a side note, I do usually run around with my parking lights on, so I am more visible than without any lights.
Diller
'99 Yukon SLT
'08 Hummer H3
662longsleeve
