So I took everyone’s advice here and decided to do a retro. I ordered the Bi-xenon Morimoto Mini Stage III Kit (H1 5000) from TRS.
I ordered a cheap OEM headlight off eBay to hack up and see how easy this install would be. To my surprise baking the headlight and opening it up was fairly easy. The rest I’m afraid was not as simple as people make it seem. You need to be somewhat knowledgeable at fabrication to take something like this on. Personally I do not do a lot of fabrication work so I did not have all the required tools, epoxy, fiberglass, bondo, etc. Also reading up at HID planet in regards to leveling, painting, sealing, fabricating, securing and anything else needed to do a retro correctly I decided it’s better leave this up to someone who specializes in this. I spent enough money on the parts that I did not want a half ass the install.
At that point I decided to contact Black Flame Customs to do this install. I had BFC order a set of replica headlights instead of the OEM headlights to save some $$ there. The install was quick and they look amazing. I had some initial issues with epoxy buildup which was not allowing one of the headlights to fully adjust with the adjustment screws. BFC has been very helpful with this issue and fixed the problem. I had them paint the inside of the headlights black to match the color of my Yukon.
The only regret I have is using replica headlights. In my opinion these are replica for a reason, the build quality is nothing compared to the OEM. The headlight adjustment screw assembly is made of cheap plastic and they do not bolt onto the car and fit like a glove like the OEM ones do. If your spending the money on a retro I would look for OEM headlights, I’m sure you can get a good used set on eBay for the same price as a new set of replica’s.
The headlights should arrive today and I will install them. I’ll take some pics and post them back up here. Total cost of the retro was just over $1,000 which includes parts & labor.
