High Output Alt?
Crowder99Yukon
I'm thinking of going with Mechman or Iraggi, not sure any input?
And if you install a ** alt are there any risks of frying anything in the vehicle?
99 Yukon 5.7
yukondenali
Kansas
For whom that answers his^ question would he need a higher cca battery as well?
yukondenali
Kansas
So I does need to be done if one was to do the higher output alt mod?
Crowder99Yukon
Crowder99Yukon
It would help for sure, I'm not sure if you absolutely have to or not.
dcil
I have a Mechman in mine, been very pleased with it. As long as you get the 12v ones with a built in reg, you should have no problem with your vehicles electrical.
Denali0229
FL
Mechman are good alternators. So are DC, Singer and Excessive Amperage. I haven't heard good things on the iraggi though.
Sent from my PC36100 using Tapatalk 2
dcil
^ All I've heard from iraggi was bad. Bad customer service, and shipping issues
scavin
ocala, fl
i run the iraggi 380 amp alt in my 97 the alternator itself is amazing however very little support/response from iraggi with my questions and took 2 weeks to ship other than that no problems, and no worries with h/o alt frying anything if you remember to do a big 3 upgrade
Kevon67
It is my understanding that Iraggi's are noisey. Couldnt proove it. Customer service not so good according to discussions with owners. I have a Stinger 220amp alt., been relativley pleased. However, a bit pricey. I have two sp1500 batteries as well, all installed back in 2007. I have a yellow top in my s10 that has been going strong since 2001. When I replace the Stinger batteries I will replace with yellow tops.
