high performance Radiator
MLRTYME
I am in AZ with ya, and have a champion in my 84 K5 blazer and my sister's 2004 Escalade EXT...but for my 2007 Yukon, I went with a Cold Case radiator. They run the wider tubes like the Mish and the Be Cool...but at a smaller price than those options. Fully welded aluminum and priced below $400. Install of course does require some trimming of the brackets (in my experience, all aftermarket aluminum radiators do...to some extent) and trimming on the electric fan shroud since the one I purchased was a thicker core than stock...but a few thousand miles on it now and no leaks. Installed in the dead of 115-116 summer and even during engine break-in it worked very well.
Now, I don't do slow rock climbing but I did have to sit in traffic in those temps to/from work and such. Not exactly the same type of activity...but this is what I can report on. https://www.coldcaseradiators.com/ Also, I am not affiliated with this company in any way. I just hate the concept of a plastic tank molded to an aluminum core...a problem waiting to happen and I feel a solid solution is better, if I'm going to bother spending the time to replace anything.
YMMV
Tozan
Tozan
Overlander
Yavapai Arizona
I got the Cold case all aluminum radiator in today and installed it. The stock radiator is only a single tube and the single tube is much narrower than each of the rows in the cold case. The two tubes in the Cold case are equal to three standard tubes. With each tube being 1.25 inches wide.
This Cold Case GMT570A is a very nice looking unit it cost $406 shipped to my house. It has a nice polished tank and the overall workmanship looks good the TIG welds look a lot better than I can do...
It comes with new transmission cooler fittings. You will reuse the original rubber mounting pieces on the top and bottom. All the stock hoses and connections are there and in the right place.
I did run into a fitment issue like Dave mentioned above the top upper bracket came in slight contact with the upper radiator support. It wasn't a real hard contact but, since this will see a lot of off road use I wanted to give it a little more wiggle room so I took a few minutes to cut some extra clearance. It may be possible my stock rubber pieces were old and very hard so they didn't allow the radiator to sit lower.
The stock lower fan housing normally fits into the area where the stock radiator does not have tubes so, the fan housing will have a gap between the radiator and the housing.
For now I just pushed the bottom in enough to hold the bottom of the housing in place and decided not to worry about the gap for now. In the future if it gives me any problems I might do some trimming to fit the housing in closer.
With the additional cooling the gap between fan housing and radiator should not matter. On my first short test drive it took a little longer to heat up and the running temperature was about 15 to 20 degrees less than normal.
Tozan
Tozan
Overlander
Yavapai Arizona
So the radiator I got had a bad transmission cooler bung on it. it has a low spot on the face of it I would guess about .030
I tried a rubber washer but I didn't expect it to hold up very long. I contacted Cold Case and they gave me the option to exchange it ( I am guessing that would take a few weeks for it going back and forth. Or they send me their dual pass external cooler.
I opted for the external cooler and it mounted up pretty easy just in front of the condenser/radiator. This unit holds a lot of oil too. It is their 12 inch dual pass cooler.
I did have to drill an extra hole in the coolers mounting foot on the left side.
bobbywdatool
