High rpm problem.
Venom
Venom
PA
Not sure. If memory serves, in my 1980s cars, we had to calibrate the IAC motor to help control the idle. High idle like that is usually a bad MAP, or MAF or vacuum leak. MAF was the usual culprit back in the day.
I can get a few more readings if that would help. I’ll stop by the junkyard and see if I can find a maf before I buy a new one. Where are some places to look for vacuum leaks?
I'm not familiar with those engines but I would check any vacuum or pcv lines off the throttle body and valve covers, the air intake hoses and if it has a plastic intake manifold, between it and the heads.
Venom
Venom
PA
Update, decided to take my throttle body back off and replace the tps and look at the iac. As I took the iac back off, one of head of the bolts just fell off, I must of broke it without realizing I did and the iac was leaking. Needless to say the problem is fixed for now I hope. Id like to say my problem was the iac leaking and the temp sensor but I don’t know
asdfcars
