Hitting brake lights up turn signals?
treehan77
TYF Fiend
Crestview, FL
Turn signal arrows in the cluster light up dimly when brake pedal is applied, go back out completely when let off brakes. Hazards is making top brake light, license plate lights etc light flash too. DIC tells me every couple of minutes "Turn Signal On" even though after i turned, the stalk cancelled and went back to right position. Don't ever see rear amber bulbs do anything when i turn turn signal on and go look, front ones seem fine. Headlights all work as normal. What's going on? Haven't been messing with, just started after i pulled over and actually used my hazards today out of the blue.
treehan77
treehan77
TYF Fiend
Crestview, FL
Does this sound like a turn signal switch failure? Anyone have the procedure to changeout ?
Burnout
