Holiday Gift Ideas
SlickCar Trever
Supporting Vendor
Its that time of year again, the time for gift giving. And what better gift is there than something that makes your life a little easier. Below are some car and truck electronics that are sure to please this holiday season. Be sure check out all of our links below to the full listings.
Car Alarms & Auto Security Systems
Remote Vehicle Starters
Power Window Kits by SPAL
Power Door Locks & Power Lock Kits
Shaved Door Handle Kits & Door Poppers
Car Alarm, Keyless Entry and Power Door Lock Kit Combo (4 Door)
Made by SCYTEK
• Remote Arming
• Remote Disarming
• Passive Arming
• Panic Mode
• Emergency Override
• Valet Mode
• Ignition Controlled Door Locks
• Dome Light Activation
• Auxillary Function Outputs
• Remote Shock Sensor Disable
• Silent Arming/Disarming
• Anti-Carjacking Protection
Scytek 2000RS - Remote Car Starter with Keyless Entry
Made by SCYTEK
• Remote Engine Start For Gasoline & Diesel Engine Vehicles
• Quick Stop Mode (Stop and Go)
• Programmable Timer Start Every Two Hours (Anti-Freeze Mode)
• User Select Run Time 12 or 24 minutes
• Start, Ignition & Acc Relays On Board
• 800-1000 Feet Transmitting Distance
• Windshield Mounted Extended Range Antenna
• Keyless Entry (Negative & Positive Door Lock Outputs)
• Tach Sense Learning and Tachless mode
• Brake Pedal Shut Down
• Hood Open Safety Switch
• Trigger Input Wire for Optional Shock, Glass or Radar Sensor
• Factory Alarm Disarm
• 2nd Ignition / Accessory Relay selection
• Starter-Disable Protection (Relay Optional)
• Programmable Double Pulse Unlock (Nissan, VW)
• Five Function Plug-In LED
• Plug-In Protected Valet/Override/Program Switch
• Remote Auxiliary Channel For Trunk Release, Power Window Control, Etc.
• Built in Flashing Parking Lights Relay
• Complete Installation Manual
Power Windows with 3 Illuminated Switches (2 Window Power Window Kit)
Made by SPAL
• Comes with SPAL illuminated switch kit part number 33040167 & 33000030 motors
• Converts 2 Manual Windows to Power Window
• Perfectly suited for any type of door, front or rear.
• Power window system is installed behind the door panel.
• Does not change the exterior design of the door panel
• Power window motors are extremely quiet.
Universal Power Door Lock Kit (2 Door)
• Converts Manual Door Locks to Full Power
• Does not require alarm or keyless entry for operation
• Can be activated by key, factory lock pin and keyless entry
• Easy hook-up to any alarm or keyless entry
• Lock/unlock the driver's door and the rest of the doors will follow
• 2 Heavy Duty Smooth Operating Actuators
• Complete Hardware Kit
• Universal Fit for All Vehicle Types
High-Powered 7 Channel Shaved Door Handle Kit (40 Lb) with 2 Door Poppers
Made by SPAL
• 7-Channel Remote
• Pre-wired Harness
• 2 40 LB. Solenoids with Hardware
• Waterproof Switch Included
• 1 Inch Stroke
• Life Cycle Rating of over 100,000
• Made in the USA
• Complete Mounting Hardware Included
Door Popper Details:
• Custom Stainless Steel & Aluminum
• Brackets Included
• Bump Stop Included
Dgrigg05
