hood adjustment
95escahoe
does anyone know how to adjust the hood on a 95 Tahoe? I am trying to get it to get it to go down a lil in the front, I don't know if you gotta adjust those rubber bumpers or what, thanks for the help
SunlitComet
OBS Jedi-Do Good
unknown at this time.
adjusted using bolt the hold hood to hinges to get even spacing between fenders and line up the the rest of front end. latch is also adjustable.
---------- Post added at 05:46 PM ---------- Previous post was at 05:34 PM ----------
Oops, forgot to add you adjust the height with the bumpers and stiffness of a latched hood with latch afterwards to fine tune fit. hinges are for horizontal adjustments.
95escahoe
95escahoe
thanks for the help, ended up moving the latch as far down as it can go and its as close to perfect as it is gonna be the pass side front of the hood is still up a tiny bit but really only notice when you start looking at it
Devs93
does the esc hood shake a lil going down the rd mine does I need to adjust mine down a lil too but prob still not enough to correct the prob. Hell Im not even touching the rubbers
95escahoe
95escahoe
nope don't have that problem at all
raptorforme93
Tampa, Fl
Your hood probably shakes BECAUSE its not touching the rubber stoppers. I adjusted mine so that the hood applies pressure on the rubber stoppers, thus keeping it from moving up or down at all.
blanchard7684
