Horn wire????????
alxs210
Reno, NV
So I have everything hooked for my train horns, all I need is the horn wire. Can someone tell me which one it is? Or somewhere else I can tap into it?
sparg93
Expedition Tahoe
NJ
Modded - great idea....
Alxs - which train horn are you running? are you using a relay to power?
Not sure on your truck, but on my OBS it's the dark green wire running on the inside of the fender wall..it's part of a larger bundle. On mine, i have two OEM horns so it's replicated on the driver/passenger fenders.
alxs210
alxs210
Reno, NV
sparg93
Expedition Tahoe
NJ
did your kit come with a relay?? If not, i would purchase one, run it off the battery and use your horn tap as the signal for the relay.
Modded
That Guy
You don't want to use an ignition wire to run a compressor unless you are planning to run the wire to a 4 point relay that is pulling the power from a thicker gauge fused wire straight from the battery.
sparg93
Expedition Tahoe
NJ
agreed - that kit is pulling 16amps and it might strain your rigs OEM system.
I would run a relay with a direct connection to the battery.
Shadfrmdabull
