Horns are IN ! ! ! !!
305Tahoe
OMFG what a Mission.....
There aint no space under the 2dr HOE
Fing car from Up North , everytime i touched something down there I felt like I was getting hit by Empty SODA cans (surface rust)
after ALL and ALL
Im SUPER DUPER HAPPY
now I even have Air to Run some Small Power tools and Air Supply in the Rear (Used/New Auto parts Sales)
blackcoffee
O.G. Black.
Wow. You did a great ******* job. How did you do the splice for Air tools and the horn ?!
---------- Post added at 10:51 PM ---------- Previous post was at 10:50 PM ----------
What kind of hose did you use, where did you get it from? The orange hose.
---------- Post added at 11:24 PM ---------- Previous post was at 10:51 PM ----------
The hoses you used are Flexsteel® Service Station Air Hose from Goodyear. I found that out, so the question still stands how did you run it for horns on a button and also for filling tires?! Also how big a tank is that?!
305Tahoe
Thanks.....
It still needs a little more work..
Need to get some Black 1/2 line as that RED is really bugging me ...Some Black Fittings to get rid of those BLING BLING ( gold) ....
Im gona run a separate pressure switch , as the tank is rated up to 300 psi , Ill run one till about 275 or 260 .. I just wana run small stuff as for my Heavy I have my trusty SNAP ON Ct4850...
---------- Post added at 11:53 PM ---------- Previous post was at 11:52 PM ----------
also as I found out today, I grounded the Really to the bracket beneath the PCm . WOW p.O.S .....
I need to reground ti as I found out this morning it was not Sufficient....
Miami-Yukon
'96 Z71 YUKON 2DR
Miami (305)
Not where I'd put the tank :imo: but looks like a pretty clean install.... Do you have a better pic of where exactly you mounted the horns at?
Just curious because I'm gonna do mine but I'm gonna be using the black 4 horn set that I already have from my old truck, they are a deeper tone than the ones you have....
305Tahoe
ill try and get a better poic of the horns..
regarding tank, it was the ONLY place it would fit ,its a 5 gallon.
blackcoffee
O.G. Black.
Well what's the difference between putting it under the truck instead of outside. It has less chances of exploding inside then out if that's what your thinking ha.
chapmanv
