Hotchkis Sport Sway Bar Set P/N 2249
Vinniety
Westchester, New York
Does anyone use the Hotchkis Sport Sway Bar Set P/N 2249 for there Tahoe? If so what are your comments about them? I have a 2002 Tahoe lowered with Belltech front spindles dropped 2 inches and rear eibach springs with air lift bags. The truck can tow fine and the bags do help but when i'm driving normal and i have about 10psi in the bags i get a lot of bounce in the rear that's annoying. I always got the bounce even before the air lift bag install. I tried different PSI in the bags to see if that helps and it does but little. Will the sway bars help out to stiffen it up some more from bouncing? I have sway bars on other trucks and i can tell the cornering is great but never thought about if it will help with the bounce.
UBILLN
sounds like you need the correct length shocks, a swaybar has nothing to do with bounce, only side to side sway...
hidpositive
+1, a sway bar wouldnt effect how your suspension really travels up and down...they more so cut down and eliminate body roll
-Gary
MrTibbs
