How can i fox/replace my 2007 Denali driver side rear (long) window?
Tozan
Overlander
Yavapai Arizona
Yes it’s a urethane (glue) installation which makes it a structural part of the body, just like the windshield. There are specific methods for a urethane set depending on if you remove all the old urethane all the way to the pinch weld or not. You can YouTube it I’m sure if you’re curious as to how it’s done. I did auto glass back in the day, I’ve done quite a few but the shop had all the tools needed. If you want to do it yourself it’s not extremely hard, but it needs to be done
Thanks I will check it out I was thinking of bolting it in but it sounds like glue will be better or at maybe a couple bolts with glue...
DaisyGirl
