How do you read Transmission Info in AutoCal?
nedor
I went with AutoCal and EFILive V2 Email Tuning. I drove about 1 hour and was able to gather Data Log and Tune File(e38) for 2008 Yukon Denali XL. However, instructions says to collect transmission data but I can't seem to find the option in Auto Cal. What did I miss?
Only mods are :
· Airaid 201-267 SynthaMax Dry Filter Intake System
· Original OEM tire was 275/55R20 111H. Just upgraded tires to BFGOODRICH ALL-TERRAIN T/A KO2 Size: LT275/55R20 115/112S D.
I am pretty new to tuning. I am basically getting the tune to fix the torque management, however, I am looking to do the following.
Default :
1. Economy Mode
2. Better Transmission shift when trying to pass a vehicle on high way.
3. Overall better response/performance from stock.
4. Currently using 89 octane but will use higher octane if there is a significant gain.
In Tow Mode :
1. More Sportier setting
2. Speed limit to 120 MPH
Are there anything else I should consider? Vehicle is for a family of 6 and used primarily during weekend or family trips.
Thank you in advance,
Ned
Oh, I sent an email out but just got a reply saying the folks at blackbear is on road trip and I imagine they guys will be extremely busy....
bzpilot
Dallas, TX
You need to retrieve both the Engine & Transmission Tune Files (for you this should be reading the existing E38 and T42 settings information from your vehicle). Then you should have also collected a single Data Log (separate from the tune files) which contains both engine and transmission data.
N
nedor
Thanks for your reply. I was able to read and save E38 data but I am not able to find T42 in autocal for data retrieval. Was I miss a step during setup?
Ned
bzpilot
Dallas, TX
If The T42 option isn't there contact Blackbear directly and make sure the Autocal was setup correctly before being shipped to you.
knometh
