How do you remove the airbag?
rockmax77
Tucson, Az
I have a 97 2-door tahoe, and I need to know how to remove my airbag so I can get down in my steering column.
Sent from my SCH-I605 using Tapatalk
_Dylan_
STAY FROSTY
there are screws on the back of the steering wheel
Administrator
Be sure to disconnect the negative battery cable first
Y2KpewterZ
On my 96 there were leaf spring style clips at each corner. Best way was to turn the wheel 90* pop the two out at the top of the column with a flathead.. then spin it back 180* and get the other two.
On my 00 (99 essentially) it had coil spring type clips.. same method though. Check out youtube for more in-depth detail.
Gzes
the drifting 2dr
Wichita tx
Pull battery, wait an hour. Can do 30 min but better safe then a bag to the face. Then get the screws out and pop out and disconnect
97WhiteYukon
Im not sure on the specifics but I know there is a certain order to disconnect everything that a shop manual can tell you. I think it goes something like disconnect the battery, pull the fuse and disconnect the yellow plugs under the column. You should double check the real procedure just in case though, not worth busting an air bag with a guess. Check a shop manual to be safe.
Sevenevez
Arizona
yup. thats how i did mine.
FIRST THINGS FIRST! UNHOOK YOUR BATTERY.. then wait 15-30 minutes
old pics from a billet wheel i did to give you a visual
turn 90 degrees
looking from the backside you can access the screws. then i think i took 2 flatheads and slid them into those slots on the sides of the screw which pshes and releases the bag then you can kind of pull / pry it with your fingertips
unclip the yellow plug
remove nut.
borrow a steering wheel puller from your local auto part store.
some wheels i can remove without it. i just give it one good yank at 12 o clock, and another strong yank at 6 and they can sometimes come right off
at this point i swapped out my wheel and reversed the process
08grey
Unclip the plug before you tug on it. Remember Unclip the plug first.
dylansmashed
