How easy is it to??
zieglerj-pdm-specialist
in 100 degree sandbox
How easy is it to change the air ride compressor on a 2004 Yukon xl Denali. It doesn't even try to pump up. I should check the fuse is it under the hood or on the side of the dash. If I have to change the compressor how hard is to from a scale one to ten??
Rivieraracing
Changing the compressor is pretty easy, only part you may have a problem with is that the 3 tiny screws holding the compressor in it's place may be rusted enough that the only way to remove them is to break them off!
Z
Thank you for the update
This helps a lot, Ill go under their tonight and spays those screws with break loose, its an industrial strength bolt breaker I got from work it should loosen them babies right up.
Z-56 Hoe
What do I do????
Houston
Check the fuses first! Then do that! Try under the hood I believe it's on that grid.
etreanor
