How high can i go with cranking and rear blocks?
1BADI5
DMV
@bowtiefreak any insight here? You appear to be pretty knowledgeable on the topic
Thanks in advance
jerryjoe28
That Guy
cabot AR
I read and seen conflicting reports here
Crank the key while the truck is on the ground or with the front wheels off the ground.
My area of expertise in truck suspension has been lowering them for the last 15 years...... so lifts are generally new to me.
Any advice will be appreciated.
LASTLY: are the OEM Bilsteins fine with a 2/2 lift? or do I need to look into shocks with longer travel?
im not kris but ill give my 2 cents lol...... it doesn't really matter if you do the keys on the ground or in the air. either way the sys will need to cycle a few times before you measure it any way. for this reason I prefer to do it on the ground. just because I don't like to go up and down on the lift every time!
on the bilsteins I would think they would be ok with just 2" but if it where me I would just call them direct. they have great customer service and will tell you exactly what you need!
1BADI5
DMV
Thanks @jerryjoe28
I ended up jacking the truck up to crank(level)the front out.
The thought of calling Bilstein has crossed my mind.
Again, thanks for your feedback
jerryjoe28
That Guy
cabot AR
Thanks @jerryjoe28
yea cranking to level is no problem.
deff give them a call. they will tell you exactly what shock you need for your truck
Rob Scariano
Omaha
Crank on ground with weight on wheels.
I've done it many times with no issues. You will get various opinions. However, I've never had a problem.
Just make sure to realign it once you get to your final height. My torsion bars are cranked to the top. It rides rough but that's only because the stock upper control arms are limited in their design.
If you want it to ride good at max crank, you will have to upgrade the upper control arms. Cost a bit but worth the investment.
1BADI5
DMV
Thanks for the feedback @Rob Scariano
I have it leveled right now, but once I buy new shocks and the blocks it will go up soon. And yes, as soon as I get it cranked and blocked its going right in for the alignment; thankfully the shop is only 2.5 miles down the street
RepublicanRebel
