llllljrlllll
So i put in 5 quartz of oil, but now i'm confused, do i need 5 or 6, I put in 5-30, can i mix it with 10-30? Thanks brothers.
I though i bought 6 of the 5w-30, but i end up taking 5 of 5w, and 1 of 10w by mistake, I didn't feel like going to pepboys again. But I end up going there anyways, to get the 5w. To make it right. I didn't mix it.6 Quarts for my Yukon, 5W-30, don't know about mixing, why would you mix the two?
Thanks, I read your post, and decided to go back to pepboys, to make it right. Didn't want to f up my hoeNEVER MIX VISCOSITY unless an absolute emergency.
Why is there anything better? You thinking off.6 quarts of 5w-30 is alll you need, I use Mobil 1... But I might change up soon.
man is that your yukon with the slides, I was thinking of getting slides for mine, but i haven't seen in my color, your yukon is the same as mine in color, got anymore pics, so i can see it better. your truck looks hot.6 Quarts for my Yukon, 5W-30, don't know about mixing, why would you mix the two?
I was going to try Amsoil
thanks bro, good reading, knowledge is power. Now I knowMixing viscosity will not hurt anything. Go to bobistheoilguy.com forums and read up.
