How much lift to fit 35's?
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
Question: I am thinking of doing a 4" spindle lift on da hoe on top of my 3" lift I got so far. I got 3" blocks in the rear, but what size block should I go with to level the rear to the 7" I am going to get in the front? I know a Add a leaf does about 1" and I have seen 5" blocks. Any other ideas? Thanks guys!
99COOP
Retired
Chicago, IL
since the back normally sits ass low, i would just go with a 4" block and an aal which will normally net you closer to 2". Other wise go all spring lift.
edit: sits high
bowtiefreak
No Quarter
Near Philly
7" blocks are a bad idea? All spring if you can afford to go that route is your best solution.
bowtiefreak
No Quarter
Near Philly
that's a big block. I would say no to that. A decent spring will make you much happier
97blackkon
Im running a 6" suspension lift with 37-13.50-17 toyo open country tires and i was runnin 34's stock with no lift so yall should be able to run 33's with no problem and 35's with a 6" lift. and my lift come with 4" block and add-a-leaf in the rear that gave me 6" all total so i would think about something more than a 4" block but myself wouldn't go bigger in a block i'd go with springs.
ghettocowboy94
