How much width does leveling kit add???
macayo
On a 2000-2006 Tahoe, if one were to:
1. install a 2" front 1" rear leveling kit from say, truxxx or rough country
2. Hypothetically keep the stock OEM rims and tires (for the sake of this example), how much wider does the wheel/tire stand?
Thanks guys!!!!!
yates ™
Resident Apple hater
Iowa
As long as there is not a drop on it which I doubt a leveling kit would it should add any width.
M
macayo
Hmm, I could swear that I read on one of the manufacturers websites that the kits space the wheels both down And outward a bit, and that there was indeed some width added.
Would this be different for a 2007-20011 model? It is possible that this information only pertained to those years, versus mine which is a 2001....
Thanks guys.
LI99HOE
Top Notch Tech.
N.Y.
Unless they add spacers in the kit, I don't see how it could change the width with OEM size rims/tires.
Most I can see 'em doing is changing the camber a bit.
brucebruce45
If anything when u crank it pulls the wheels in doesn't push em out
Splatmaster527
Cleveland, OH
you are basically just moving the suspension up a bit in its travel...
there is no outward movement
just think it through... does your width change with suspension flex?? no
Jbird
nope it doesnt if anything there are farther in. Until you get it aligned and the camber right
Juwan7233
