HOW-TO: 03-06 NBS Gauge cluster LED conversion
treehan77
TYF Fiend
Crestview, FL
It was a 20 or so option when I sent my cluster off. If you haven't done that already you should consider it. By itself someone else may come in?
blatta1999
Took my gauge cluster out today and replaced the stepper motor on the speedometer. All went well and worked as it should. Now I have on order bulbs and the rest of the motors to go ahead and completely rebuild the gauge cluster. Thanks for the valuable info on here!
blatta1999
Is there a bulb that goes to the mileage readout and the gear readout(PRND321)? Both of mine are dim and I am wondering if I swap all bulbs to led will that take care of it?
treehan77
TYF Fiend
Crestview, FL
Search prndl reflow. The bulbs probably aren't the culprit, a bad solder joint is.
Zonk 1-75
