How to clean up/restore rims?
rmodel65
If you do this then just make sure you reclear them.
Sent from my SCH-I535 using Tapatalk
or just leave them bare and wax them and repolish every so often..iirc por15 makes a very hard wheel clear coat for redoing wheels
Paul-ish
I'd sand them and paint them gloss or matt black... But that's just me.
You could do the paintstripper / polish them and clear them... That's a lot of work and you better be good at polishing though.
Or you might want to see how much to get them powder coated...
2000tahoeZ71
Are these the wheels that came on it from the factory? I had a friend with a 96 2d 4x4 that had these wheels and he claimes they were the original wheels. Possible dealer option?
Paul-ish
They might have been dealer installed but they were not a factory option...
Nak
You're going to need to get them bead or sand blasted. ( I think Aluminum has to be bead blasted?) Acid will eat the corrosion, but will leave the pitting. I'm in the middle of refinishing some aluminum rims, and your rims look scary for DIY. Too many corners and protuberances for hand sanding to be worthwhile. If you just want to paint them, acid might work. Use a primer that will fill in the pitting at least a little bit. Plus, you'll need to prep the aluminum properly before you paint. Check with a good auto paint shop.
BTW, that's if the surface is aluminum. (I can't tell from the pics...) If it's chrome, don't bother. Chrome wheels are basically "throw away" pieces. Refinishing corroded chrome won't last long enough to be worth it.
Polomatt
