How to install aftermarket amp bose system?
Ponchonutty
New Washington, Ohio
you don't want any of that speaker wire sub adapter crap.
You want the module that goes directly behind the radio and hooks into the pre outs from oem radio.
This is plug n play and gives best sub outputs next to a aftermarket radio.
this is not for your vehicle specifically, but to show you what you want. use the vehicle selector to get your model.
http://www.carid.com/pac-audio/ampl...mgm1416.html?gclid=COew5fOh9MQCFQsvaQoder0AQw
Using this interface the bass output will deminish when you turn up the volume. The one I listed will correct that
---------- Post added at 04:34 AM ---------- Previous post was at 04:33 AM ----------
thanks.
can you comment on the aftermarket amplifier location, or how the rest of the speakers for the cars equipped with the bose setup are powered?
Is there a separate amp for the rest of the speakers?
All speakers except tweeters are ran through the factory amp
paintpollz
[/COLOR]
thanks.
so. if you were happy with the stock surround speakers, and wanted to upgrade the sub....
1. install a new multi channel amplifier in place of the stock one to power the new stealthbox center console sub and factory speakers.
2. install a new center console stealthbox, powered by the factory sub.
3. add an additional mono block sub, assuming under the driver or passenger seat, to power the new stealthbox center console sub.
My factory center console sub is pretty much blown at this point. I don't need earth shattering bass, but I'd like a proper upgrade. Please post suggestions. Thanks, Kevin.
ehernande86
