Gzes
the drifting 2dr
ok well heres a tutorial on the mirror instal. firs off you need to get the screw that is ontop of the part where you close the door from the inside
[/IMG] once you get it off you will need to put the filips head screw driver in the trim that holds the power windows and locks. theres 2 clips and its easy to get off
[/IMG] now pop the clipsthat go around the handle and locks. there are a couple of clips so put it in and pop them out carefully. from top to bottom but the left and bottome one can be tricky
[/IMG]
[/IMG] now its time to pop the panel off. remeber some will break its gonna happen just try not o bust more than 3
[/IMG] i do it from the outer side then go down the go up on the inner side and it works good for me. next you can do 2 things. you can unplug the buttons or put everything throught the panel. i couldnt get them unplugged so i went through the panel
[/IMG] now with the panel out of the way you can access the bolts to the mirrors. remove the foam by pulling it out
[/IMG] the bolts are 10mm size and i used a socket and extension for the outer 2 and the 10mm and small rachet on the inner one. this is the inner one
[/IMG] once all bolts are out the mirror is holding on by the foam so just start pulling and it will come out. now you can disconect the mirror. on the passenger side you can take this off and unplug it from here
[/IMG] or take the trim off on the inside which takes more time. once unplugged bolt the bottom 2 bolts in the mirror first then place the metal on the door and bolt it up for no vibration
[/IMG] you can put the foam in before or after the plate i did both ways.now just reverse the dissasembly and your done. one thing tho is on driver side it unplugs at the mirror because the plug at the bottom splices with the power locks and button that controls the mirrors
[/IMG] thats about it if yall have any questions pm me or ask away on here. this is also similar on the 95-98 but you dont need to remove the door panel.
[/IMG]
[/IMG] thanks and sticky would be great
