[HOW TO] Install Venom Trucks Amber Switchback DRL Kit on a 2021+ GMC Yukon (Plug-N-Play)
fondupot
Senior Member
South Carolina
Did a little collaboration with Venom Trucks recently. I installed a set of their amber DRL switchback harnesses on my 2021 Yukon. This is a 100% plug-n-play harness that gets plugged in line on the back of the headlight. This kit switches the DRL from the standard white LED to the Amber LED. I personally prefer amber running lights, and this mod really sets the truck off. The LED strips will automatically switch back to white at night when the headlights come on so they match, and you can manually switch the DRL back to white if you use the lighting control knob in the cab (during the daytime).
Install is not too bad, getting to the connectors is kind of a PITA. Access is thru the wheel well. And space is tight, but it can be done in about an hour and some patience.
Visit: venomtrucks.com to learn more. They have other GM vehicles available to and will be expanding their line in the future.
Checkout my install video.
lordmorgul
