How to on replacing turn signal switch on 96 tahoe
RSymons
Texas
I changed my turn blinker switch out a few months back. It is definitely a tight spot to work in. The worst part was unplugging the turn blinker assemblies wiring under the dash board and then pugging it back in, its held in by a bolt and it was hard to get to, but it is pretty straight forward. One screw at a time!
Good luck!
blizz
San Antonio, TX
Just wanted to bump/update this thread. As mentioned in another thread, I finally got around to doing this and it fixed the issue with my turn signal. It was a pain in the ass but I'm glad it's done. Some advice, you don't have to take the air bag off, just remove the fuse and wait about 30 minutes to be safe. Also the connector for the cruise control is a real ***** to get off. I ended up taking some wire cutters and clipped the retaining clip off. Cut the wires going to the cruise control module so you'll have more slack and if you can, unsnap the cruise control module and slide it off the guide rod for better access. I came across this accidentally when I inadvertently popped it off. Last thing is to be careful with the screw behind the steering wheel. Turn the wheel to the left as much as you can and get the bit in there and use a wrench to turn it enough to loosen it. Then you can take it off safely. I almost stripped my screw by going in at an angle.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I have said it once and I will say it again. You remove the abs fuse AND disconnect the 2-wire yellow connector for the bag and no waiting 30 minutes. The bag unit does not retain a built up charge. That is what the DERM is for. Diagnostic Energy Reserve Module aka air bag module. it only retains the juice to blow its load for two minutes from key off, battery ground removal or fuse disconnect. When the yellow connector of the bag is disconnected service work can begin immediately.
patniven
