How To:Samsung Galaxy Tab Stereo for Bose trucks
mharders
Just outside of Seattle
How do you run a aftermarket amp off this set up? I see that you pulled the remote wire from the gmos04 but what about the RCA hook ups?
ballsie
ballsie
austin texas
I only have a subwoofer amp. I am using a line output converter spliced into the speaker wires feeding the factory sub under the center console.
You could use another RCA splitter and run more RCAs to another amp.
04blackout
So this would work with my pac audio adapter I have for my amp which is currently used with the bose system? If I understand correctly it looks like that would stay the same bc its behind all this new wiring
Can you stream pandora from a phone (unlimited data) to the tablet via Bluetooth?
ballsie
ballsie
austin texas
No streaming required. Just tether the phone's internect connection and install the pandora app on the tablet
04blackout
just found out bc im on an old unlimited plan i cant use my phone as a mobile hot spot
****** att
mharders
****** att
Yup, just learned that myself. It's messed up, they told me I would have to cancel my unlimited plan and buy a lower plan so I could use it to tether my other devices. Scandalous :mad:
Ballsie you got a pm
FLDataTeK
Sanitation Engineer
Jacksonville, FL
I love it when unlimited really doesn't mean unlimited.. They should look it up in the dictionary. They need to stop with the marketing BS...
ballsie
ballsie
austin texas
A quick iphone jailbreak will solve the tethering problem with AT&T.
Snefferz
