Huge hesitation, mechanically inclined. Please help
Brian Wilson
Brian Wilson
So done with this issue. I will post my solution when it is found. With the high miles im just going to build a new motor for it in my spare time.
Speck
Olympia, WA
I wish I had useful info to help your situation. Sounds like you've been covering all of the options. Best of luck with building a new 6.2. Sure is reassuring with you having that high of mileage and just starting to have an issue. I hope you're able to resolve it soon.
retiredsparky
If the traction control system is activating the brakes (your post about seeing pressure from the bleeders), shouldn't you focus your troubleshooting in that area. I have been watching your logical process, you have pretty well covered the engine related components. Building a new motor will perhaps be therapeutic, and certainly will give you more power. But if the sensors and or module for the traction control are malfunctioning, having more power will not make you go any faster.
I have never messed with the T.C. system, but as smart as you are, you may be able to figure out how to check it. There should be some sort of gyroscope device that monitors angular momentum. The abs sensors probably play a role as well, comparing wheel speeds, that way a separate set of sensors would not be needed. There is a sensor on the steering shaft under the dash, I believe, that provides information about requested steering angle.
Traction control basically limits engine power, applies brakes as needed and screws with your mind. Government goals all accomplished.
Can you disable your traction control by pulling the fuse? Pushing the switch to disable the traction control may not turn it off, if it is malfunctioning!!!
Good luck,
Larry
Brian Wilson
Brian Wilson
A sensor to measure steering angle, gyroscope to measure momentum?!? I really hope you are messing with me. Surely to god these don't exhist in my car
Brian Wilson
Brian Wilson
Good info larry. I did pressure bleed them and so far no problems. Been a few days. I didn't want to post that it was fixed until I knew for sure. I also filled up with some 107 octane fuel after the knock sensors didn't fix the timing issue. Still retarding the timing just as much. And since I already pulled the top of the engine apart a month ago I know it's not valve train noise. Has to be piston slap I figure. I doubt a forged rod bent in a stock engine that has never been pushed hard. That's why I'm building a spare engine. I'm going to ask blackbear to tune out the knock sensors or at least make them a lot less sensitive in the meantime.
Chip18
Dayton NV
Well there is certainly no harm in "walking away" when you come up against a wall.
Yes ... yes they do! If the system "thinks the vie is outta control ... it cuts power and applies brakes to regain stability.
Most likely you would not be checking "stuff" that you don't realize is there. :)
Maybe ... you have multiple sensor failure/issues that combined to be a major "PIA???" The "Piston Slap think in these motors 6.2?? (Gotta check on that one) is pulling power?? A fault/ or over sensitive "Knock Sensor???" It sounds like the BB Tune maybe able to help you there."
Speculating here ... but disabling systems individually may help you isolate the failure?? Disable the knock sensor and run "Premium" and see if there is still a loss of power?? Disable the "TC" and see if the brakes are still dragging??
I don't know how to disable those systems but it makes sense in my head. But if it's not the motor??? But is infact a system failure somewhere in the vehicle?? A rebuilt motor won't solve the issue and ... that would suck!!!
Brian Wilson
Brian Wilson
I agree. It would. I hate to say the brake issue is "fixed". But it looks like it was just air in the abs motor. 3 days and zero drag. But the timing is definite being retarded 30 degrees at times. It threw a knock sensor code finally. Replaced the sensors and calibrated them with a proper computer. Still got a knock code after 5 minutes of driving. I understand this thread makes me look kinda dumb but, I'm pretty good at troubleshooting and systematically eliminating potential issues. Usually. Short of pulling my engine and taking it apart, tuning out the knock sensors is my best tool to eliminate 'knock' as the problem.
Brian Wilson
Brian Wilson
I used the 107 octane to eliminate detonation as the cause of 'knock'. And I know I don't have any misses. Finally, I feel like I'm down to my last possible cause for the issue. If not, I will admit defeat, keep paying my full coverage insurance and pray my 0 Guage stereo wire doesn't short out next to a 2 gallon plastic gas can where my subs used to sit. >8-D
Chip18
Dayton NV
Well I would hardly say this thread makes you look dumb?? I'm impressed with your ability to "troubleshoot!"
"Tackle" one of these issues at a time. If you've calibrated/replaced the "Knock Sensor" and it's still pulling timing??? That's not right??? Maybe it's the PCM/ECU?? Can you just disconnect the knock sensor and drive it and see what happens???
And under the heading "Stuff I know" on the TPS on GM's, there should be a yellow wire and it should always have 5 volts, if it does not that points to a problem with the PCM/ECM???
TahoeCruiserV3
