Humming from front
bsamoul
Hoe Enthusiast
Walnut Creek, CA
Hey guys, about a week ago I noticed a humming sound coming from the front right (passenger front) area of the car when I'm coasting at relatively low speeds. Sometimes it's louder than others but I can hear it with the windows closed and the radio on. It's usually once I've been driving it around a bit.
Anyone have any ideas on what it could be??
99Yuk
Northern Ontario, Canada
Ya, my first thought was wheel bearing too, but then he says it only happens after a bit of driving? When my wheel bearing went, it growled right away, as long as it was turning.
What happens when you turn left? Is the noise louder of softer, or does it go away?
What happens to the noise when you turn right?
Variations there, almost certainly point to wheel bearing.
piranah
also what about tire wear/pressure? could have something stuck in there...
maybe brakes? as the rotors heat up they push on the pads? but im guessing you would notice a difference in breaking...
B
bsamoul
Hoe Enthusiast
Walnut Creek, CA
I've only really noticed it while going straight, not turning
BigDawg99
NB Canada
I am getting the same problem with my truck..02 Denali..loud humming sound coming from the front end..straight..Left..right..always there...sometimes the noise will go away and 5 to 10 minutes later..the noise comes back with a vengenance...what did you end up doing to your vehicle..was it the wheel bearing
SunlitComet
OBS Jedi-Do Good
unknown at this time.
something like at certain speeds of various vehicle parts things vibrate making noise. Sorta kinda...
---------- Post added at 02:31 PM ---------- Previous post was at 02:12 PM ----------
Sould have said resonant noise. sorry.
DaisyGirl
