I’m being told my engine is bad
R3cord303
Posse In Effect
Oregon Valley
That doesn't sound like bottom end damage at all. Bottom end damage will make it sound like an old clapped out diesel tractor.
Big Mama
Virginia
The echoing of the pan does sound like a bottom end but most bottom ends sound like sticking something in a metal fan. The faster the fan the faster and louder the noise. If it is just the bottom half no need for a new engine just a short block. Did the 2 shops remove anything or just diagnose from below? I think this was asked is the oil level ok? Also on bottom problems the drain plug usually has metal shavings on it.
Michigan
Michigan
Oil level is fine
I wasn’t around for the diagnosis at the first shop but he claims he removed the cover for the flywheel to check that. I think they just went by sound and didn’t take anything else apart
Second shop I was there and they just lifted the truck up and just from the sound all three shop guys concluded it’s definitely the engine.
I know mechanical things do fail suddenly but would an engine that’s been running strong just develop this loud sound suddenly without warning? I.E wouldn’t it develop a small sound and gradually get louder and louder as time went by?
Like I said though the noise is not really there when idling but when revving the engine in park it consistently does get louder. I’ll have to another video as well as get in into a different shop
to rule out the flex, you take the three flexplate bolts to the torque converter, then fire it up. if its the flex the sound will be gone, if its still there its the engine.
does kinda sound like a flexplate. unless you broke a connecting rod, never heard a rod knock like that before, its more of a rhythmic banging sound.
Could you clarify a little on what you mean? To rule out the flex plate or not. Thx.
Scottydoggs
NJ
if you un bolt the tc from the flex, the engine wont be spinning the tc, you can also hit it with a hammer lightly, if it rings its still good, the flexplate that is. they dont ring if cracked. if it is broken, it should be silent or rattle way less unbolted.
once unbolted you might even get some play if you push and pull the flex. it should be tight and not move in any direction other then spinning round.
just recalled these dumb tranny dont have a open inspection cover. makes this job a bit harder for a inspection.
ivin74
05 NBS Nali
Htown, Texas
Buy a 60 dollar inspection camara an look at the flex plate. That rules out the flexplate.
The sound and symptoms really do sound like a cracked flex plate. You said the shop said they "removed the cover and all the bolts or screws where there". Yeah, you're not looking for loose or missing bolts. You're looking for cracks, either radial or concentric. They can be difficult to see through the small inspection hole and the at angle from which you're forced to inspect it. I'm with @Scottydoggs on this one. I'd unbolt the starter and use a large screwdriver or small pry bar to GENTLY pry the flex plate fore and aft. I say gently cuz you don't wanna bend it and make it a problem/an additional problem if it's not the problem.
Michigan
Michigan
Edit I thought you guys were talking about flex pipe. Is flywheel and flex plate the same thing but just certain cars use one or he other? Like a timing belt bs a timing chain? Sorry. As you can see not my area of expertise
Thanks for the input everyone.
To answer your questions the shop said they first checked the flywheel. They said they removed the cover and checked for that and supposedly it was all good and yes even with the flywheel you’d still be correct they wouldn’t be looking for missing bolts or screws, they still be looking for a crack
Neither shop has made any mention of the flex pipe but before I created this thread I listened to a video with a bad flex pipe (can’t find it right now) and it sounded similar.
I don’t work on my cars and not very knowledgeable about the way the drivetrain and engine works but it’s always good to act like I do when taking it to a shop. So should I suggest the shop to check the flex pipe off rip or should I take it in again blind and tell them I’m hearing a noise without telling them other shops think it’s the engine or flywheel and also if I ask them to check the flex pipe they should be knowledgeable to check it without damaging it the way you describe right
Jeff Groves
Retired Demo Expert. I don't need to run anymore!
Nevada, Ohio
You say Fly wheel. I say flex plate. LOL!
A Fly wheel is used on a standard transmission where you have the pressure plate.
Flex plate is used on an automatic transmission.
2 different chunks of steel.
hillcreekfarms
