I’m being told my engine is bad
The video finally uploaded
Sorry not a great video. It was taken very quickly before work yesterday. I’ll try to get a better video and get the camera underneath the truck
Oil pressure has been fine. I think 40psi at idle and 60psi on the freeway.
That ain't no bottom end problem, that's the flywh... err flexplate. Tighten the bolts first and then look for cracks. Don't go back to them guys, they are either ignorant or thieves and care more about what's in your wallet than fixing your truck. If they succeed in scamming you out of an engine, replacing a cracked flywheel is cheap and you'd never know.
Guys like this is how I learned to turn wrenches!
Michigan
Michigan
I think the first shop was trying to get me but honestly feel like the second shop was ignorant if this ends up not being an engine problem because they weren’t even aggressive in trying to service it. They said they would do the job if they can locate a used engine from a place they deal with. Not sure why it would be hard to locate a 5.3 anyways but they don’t rebuild engines at the second shop.
How much should a flex plate job cost at a shop if this turns out to be the problem?
Also one more question, if I drive the truck 30 miles to a shop is that ok? Although I may stay local.
I wouldn't let any shop touch my truck if they couldn't determine if a noise was caused by something mechanically broken or an exhaust leak.
Since exhaust was brought up, broken chunks of catalyst in or from the converters or even a baffle inside the muffler could rattle around and make a similar sound that could lessen or go away once the parts expand from heat. But your sounds seems much too loud to be that.
Jeff Groves
Retired Demo Expert. I don't need to run anymore!
Nevada, Ohio
Exactly! They want to soak you for as much as they can get out of your wallet!
You don't even have to drop the transmission to fix this.
Remove the drive shaft and move the trans back a few inches.
If done right? It's maybe a days work on a 2 wheel drive.
About the same as a rear main seal replacement, plus the cost of the flex plate. You should have the rear seal replaced since it'll be torn down to that point. Actually, you could call around to shops to get a quote on a rear main seal replacement and just have them install the new flex plate you'll so conveniently have in the passenger floorboard.
ivin74
05 NBS Nali
Htown, Texas
The flexplate is no expensive its the labor, you have to drop the transmision or move it out to replace it. I have seen shops charge between 400 to 600 to drop the transmision.
Michigan
Michigan
Yeah I figured the labor would be the cost. Do you recommend taking to a transmission shop specifically or any reputable all service shop will do?
Jeff Groves
Nevada, Ohio
I'd ask around to see if I could get leads on a good shop.
The transmission does not need to be dropped if it's a 2 wheel drive.
If it's 4 wheel drive? Your gonna pony up some bucks.
hillcreekfarms
