I Knew i had a bad vibration but not this bad...
Fonzarelli
I thought my tires were going bad because i only got the vibration at 65 miles plus
Went in for an oil change and low and behold... just installed a used unit and its working fine but i still have vibration. I am going tomorrow to get the differentials serviced and i hope nothing else is damaged
Fless
Super Moderator
Elev 5,280
So the crack was before you replaced the stub housing, correct?
randeez
south florida
gotcha ok....i thought that was the replaced one.
in either case, that isnt a common occurrence i would look into what would cause that to break it may also be the source of your vibration. the only weight on it is the diff itself
89Suburban
Bull in the china shop
SE PA
o_Oo_O:confused::confused:
lilbit1984
