I need an obd2 scanner
tired2008tahoe
ottawa canada
I have a decent obd2 scanner that gives srs abs and engine scans but it doest do much after that. Is there a scanner I could use to scan the body module for air conditioning parking assist abs bleed would be nice too? I am look for upper midrange prices so 100-300$ will do. I am tired of the cheap stuff
chinacardiags has them right around $300-350 there a clone but that's the best your gonna get unless you spend a grand for one that may be a clone anyway.
but anyway that is the tool you need for these trucks same thing the dealer uses.
wsteele
Yes, Tech 2 clone or real used one if you are feeling flush because you kept that tired '08. If you get either, make sure it has the 33.004 SW.
GunMonkey
