I need some help please :)
Donnie Yukonie
Yates Caretaker
does the truck even attempt to turn over if not try to hit the bottom of the starter with a hammer whille someone turns the key if this starts it DONT SHUT IT OFF until u have a starter to replace it with once u shut it off if it starts this way the starter is bad
96yukgt
Can it be jumped off? If not then most likely a starter problem. BTW how did you get the alternator and starter tested?
Donnie Yukonie
Yates Caretaker
well most autozones and stuff can test for battery an altenator out puts but never heard one for the starter ?
SamoanYukon
American Samoa
The same problem occured when I first got my truck and I did the new battery & starter thing. It worked then it happened again. But now the post connections were smoking and hot. Found out that the engine froze with cylinder #6 not firing. Turned out to be a head problem (water leaking into the cylinder) causing the engine freeze. Replaced heads and she's running like a champ.
The problem happened again but now without the smoke and heat from the terminals. Figured it was due to loose side terminals. Somehow the side terminals were bad and could not be tightened (probably from all the heat from the first time). So I changed it to top post and it starts fine now.
Hope this helps.
15PPVMAC
